doanhai.bui Posted November 3, 2016 Posted November 3, 2016 My Hotpoint washing machine has been turning off at the end of the cycle, and I have to keep turning it on to finish the cycle, multiple times. Only happens at the last 30 minutes of the cycle. I notice that whenever the machine is shaken, whether by someone (when it is on but resting) or by the spinning/ rinsing (mid cycle), it goes off with no error code, just off. I think it's the vibration that loosens something and turns it off. Tried to open the top, but nothing loosen. Any suggestions to fix this thing, as I want to try to fix it first before spending on a new one.
Root Admin Whitegoodshelp Posted November 7, 2016 Root Admin Posted November 7, 2016 Check the plug and wall socket - especially if the socket is behind the machine first. I've known washing machine hoses resting against a wall socket's on off switch start to turn it off during spin. Also there could be a faulty connection in the wall socket. If the wall socket is behind the machine try plugging into a different one. doanhai.bui 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
doanhai.bui Posted November 13, 2016 Author Posted November 13, 2016 Update: It shows the F-09 error sometimes, and the led screen keeps flickering while running. Would you suggest buying a new PCB or just get a new washing machine?
Root Admin Whitegoodshelp Posted November 13, 2016 Root Admin Posted November 13, 2016 Error F09 on Hotpoint washing machines usually means "set up error" - "incorrect or faulty Eeprom" which is the main chip. I would not get involved in buying and fitting a PCB. Many of them have to be programmed and you may need software to do it. You could try sending it to a specialist in repairing and reconditioning them like QER but only if you are determined to try and get it fixed. doanhai.bui 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
