Ajazahmeduk Posted August 26, 2016 Posted August 26, 2016 Hotpoint BWD129 door locked and only door lock light flashing washing machine works fine and drains fine door can be opened with piece of string have changed door interlock but exactly same problem please can anyone help thanks in advance
Root Admin Whitegoodshelp Posted September 12, 2016 Root Admin Posted September 12, 2016 Sorry Ajazahmeduk I found it tricky to work out what your problem was with the description - do you mean the door is jammed shut and you can't open the door unless you use some string? If so and a new door interlock hasn't fixed it I'd have to suspect the door catch on the door Washing Machine Door Will Not Open Ajazahmeduk 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Ajazahmeduk Posted September 13, 2016 Author Posted September 13, 2016 Hi Andy the washing machine runs through a cycle ok but when it finishes the door lock light flashes. No other lights are on or flashing. i can only open the door using a string around its frame. I've changed the interlock but didn't make a difference. the catch on the door seems to be working OK as I've checked it with the door open.
Root Admin Whitegoodshelp Posted September 20, 2016 Root Admin Posted September 20, 2016 Does the door only not open at the end of a cycle or will it not open at all without the string? If it won't open without the string it must be some mechanical problem with the door mechanism. if it opens OK but just not at the end of a cycle I'd suspect a possible pressure system blockage if there is a system in place to stop the door opening with water inside. A blocked pressue system can trap air in the pressure chamber and make the machine think water is inside when it isn't. But it could be aborting due to a different fault. Ajazahmeduk 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Ajazahmeduk Posted September 20, 2016 Author Posted September 20, 2016 Hi Andy, Door will not open at all without the string. Door light flashes. If I unplug it, it still won't open ive replaced the interlock mechanism but how can I check that it is working ok (replacement could be faulty as well) Thanks
Root Admin Whitegoodshelp Posted September 21, 2016 Root Admin Posted September 21, 2016 Whatever the string does when it opens the door, the door open button or door catch should be doing. You have to operate the door open mechanism and work out why it isn't pulling on the bit that the string is pulling on to open it. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
