Please advise: There's a horrible noise. It only occurs pre spin when the pump is draining water, I have checked for blockages in the drain pipe and also emptied the lint tray.
Sounds like there's something inside the machine. It could be inside the outer drum or in the sump hose leading to the pump. It sounds like it occasionally gets sucked into the pump and tossed out again. Check inside the sump hose and pump first.
Ok thanks I will see if I can get to it.
Let us know how you get on, check my article on how to remove something stuck inside the washing machine
