sofiasandoval Posted July 4, 2015 Posted July 4, 2015 I have a LG front load washer (#WM2016CW). I notice that after each wash cycle, a small puddle of water remains inside the tub. The clothes that sit on top are in perfect condition--they are almost dry, but the clothes that sit at the bottom are wet due to the water that has remained in the tub. My machine spins perfectly, makes no weird noises, and drains with full power. I replaced the drain pump thinking that it had gone bad, thus contributing to the water remaining after each cycle. But this didn't do any good--the water still remains. It is important to note that when I do a "rinse/spin" cycle with no clothes in the tub or a "tub clean" cycle, no water remains inside the tub after the cycles are complete. On occasions, when my load of clothes is small enough, no water remains in the tub either. Since the clothes that sit on top are almost completely dry, I wonder if the machine completely drains when it should, but then something allows water to get back into the tub thus wetting the bottom clothes. Is that possible? Also, since water drains full force, I cannot imagine there are any hoses/pipes clogged. I've checked and found nothing. Also, no error number has ever appeared on the screen panel. What can be the wrong with the machine? I appreciate any help I can get! Feeling frustrated...
Root Admin Whitegoodshelp Posted July 6, 2015 Root Admin Posted July 6, 2015 Since the clothes that sit on top are almost completely dry, I wonder if the machine completely drains when it should, but then something allows water to get back into the tub thus wetting the bottom clothes. Is that possible? That's the only explanation I can think of. If the laundry on top is dry it must be spinning perfectly OK, it can't only dry some of the laundry. Is it usually when laundry is left in the drum after spinning? Check this article out washing machine fills with water when off Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
