tinamay77 Posted November 24, 2014 Posted November 24, 2014 My hoover washer is 4yrs old and recently I have found my clothes smelling foul after washing and drying. I regullary empty the drain and clean out the soap drawer and put through the recommended cleaner in the drum.Any ideas what is causing this? TIA
Root Admin Whitegoodshelp Posted November 25, 2014 Root Admin Posted November 25, 2014 Hi this is covered in the common faults guide here Get rid of washing machine smells Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
hman Posted December 2, 2014 Posted December 2, 2014 I used my Hoover washer dryer for 22 years, and found the condenser to be a weak spot. If you have some skills in DIY (do read the safety warning of this website) you might consider taking out the condenser. Inside fresh water is sprayed into the hot stream of air circulating, thus cooling the air and providing condensation starting points at the same time, therefore drying the air. Unfortunately spraying water does mean limestone buildup if your water is full of it. Also, some lint in the airflow might accumulate on the limestone, and the combination might be a spot where black mould can grow. With my Hoover I have to repeat taking out the condenser and throughly clean it with some acid every two years... At least my model does not have any way to flush out the interior of the condenser, so it has to be taken out every once in a while. I never had smell that came from the washing part of the machine, only from the drying part... Hope this helps Oliver
