I have an Indesit IWDD7143 washing machine and dryer combo. It had initially fail to drain water out and water was leaking from the ceased drain pump onto the the floor.
I then opened the pump and cleaned it out, I found a hairpin, and also found some coins in the drain sump. I did not buy this washing machine from new so could have been from previous user.
I replaced the drain pump for a new one of the same type, however it still does not drain. Everytime the machine comes to the cycle it needs to drain it would stop. Even if filled with water and I want it to drain using the drain mode, after 2 mins of nothing happening it may put the F11 error on.
I checked the voltage to the pump and it is getting 152volts AC, I do not know if this is enough, I guess it needs the full 230v AC to spin the pump.
I even opened the PCB module after and found a burnt out varistor TVR07471. I tried to find it online and no where in the UK seems top have them; nearest value I got was Varistor 180 pF 25 A 775 V from RS Online.
I fitted this to the circuit board, but still no cigar.
My last option I guess is to pay £94 for a new PCB module. Does anyone else know any different what would cause the pump not to run.
My PCB code is 215011572.01
S/N 1318404682
SW 16.00.19
They don't sell spares for pcb boards, or at least the manufacturers don't sell them - only complete boards. If the pump didn't have a neutral return it wouldn't run.
After the problems with my old PCB module, I had bought a new board of Amazon, plugged it in and it gave a F09 fault. Called the company up and they said no it is not programmed, was very upset especially as it was listed for the IWDD7143UK.
I have almost given up with this as it seems no one may repair the old board.
Strange is the new board is made by Delta Electronics, INC
Code:21501022702
S/N:1404304387
FW1:16.00.13
Long bar code:131215010227021404304387
The old one is made by COMPUTIME
Code:215011572.01
SW:16.00.19
S/N:1318404682
Long bar code:091215011572011318404682
Any advice anyone?
F09 on Indesit washing machines is usually "EEPROM error" which is the software chip. New ones often need setting up and programming as they are often the same boards for different models with different features and wash cycles. They shouldn't really be selling boards to the public if they need configuring without at least mentioning it. I wonder if it's possible to put in the old chip from your old board?
Other than that try researching Indesit eeprom. You could also try sending your old board to QER repairs who repair boards.
Same thing I thought. I was upset they didn't mention it was not programmed. Others did mentioned they were not programmed, I assumed this one was.
I was thinking about changing the EEPROM over, but now found another site that says they can do an exchange on my old one. https://emwelec.co.uk I had contact them as it was not listed. So fingers cross and I would see how it goes from there.
Yes that's another company dealing in repairing timers and modules.
If it was a new part and in original packaging and therefore resell-able you can send it back for a refund under the distance selling legislation within 14 days. You don't need a reason.
Thanks for the advice. I did return the other non programmed module back.
I got my original one repaired back from EMWELEC. They replaced a varistor and 4 other components. Plugged it all back up and still got the F11 fault code. My heart sank, it still was not draining.
Then though let me go over all the wiring. I took the connector back off from the module that links to the drain pump. tightened the pins inside them at both ens then made sure it was on firmly. Tried again and it worked at last, finally. I don't know if the wiring is at fault or connector pins.
The PCB module opened
Connector at PCB, two red wires come from drain pump on the 5 pin connector
It might have been that the connections needed tweaking up after taking them on and off a few times? F11 is a different fault to what you had before (F09)?
