Hi there
Our Beko WM5100W has a badly torn waste pipe :(
I've found replacement waste pipes online but i'm struggling to understand how i go about removing the broken one from the back of the washing machine.
It sounds simple enough but i cant grasp how, I'm confident with taking it apart depending on how much of it has to be disassembled..
I'm attaching two pictures of the back of the washing machine , hopefully this helps?
Any help would be very much appreciated.
post-2740-0-74466000-1405624805_thumb.jp
post-2740-0-10637300-1405624807_thumb.jp
The drain hose just goes into the machine and is attached to the water pump with a hose clip. With the back off you should be able to see, it should be very straight forward. If you can't get proper access from the back you might need to completely disconnect it from the power and fill hose and lay it over on its front to get underneath.
