paddymac Posted October 9, 2013 Posted October 9, 2013 This machine although old has hardly been used and was working fine. The drum does not move during any cycle, I have cleared the filter at the bottom kick plate. I have checked the black hose on the bottom for blockages. I have removed the top and checked for bad connections from the control block I have checked that the motor cables are not lose. The belt is intact and I can manually turn the drum I don't know if the problem is the motor or the switch block or something else. The machine fills and empties and blows hot air. The switch/Dial does not turn automatically as it should, when I manually turn it slightly it starts the next phase of the cycle but without the drum moving. I don't know if the dial wont turn because the drum has not turned. What could cause this?
paddymac Posted October 9, 2013 Author Posted October 9, 2013 also just unscrewed the white bottle with a black hose from the bottom rear of the drum, blew in it and could hear the click on and off
Root Admin Whitegoodshelp Posted October 9, 2013 Root Admin Posted October 9, 2013 Motor not running could be many things, I have general advice on it here - http://www.whitegoodshelp.co.uk/washing-machine-not-spinning-drum-not-turning/ Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
paddymac Posted October 9, 2013 Author Posted October 9, 2013 I have read that article thanks, my drum does not revolve at any stage, and the dial does not click through the cycle by itself but will change mode when i manually turn it, but still no drum action
Root Admin Whitegoodshelp Posted October 10, 2013 Root Admin Posted October 10, 2013 Hi, with a fault like that, if the article doesn't help it can't be anything straight forward so I have to advise getting an engineer. I covered everything I can think of to help in it. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
