Hi!
I would be so grateful for any kind of help with this issue. Our machine, which is about 2 years old, started leaking today. I opened it up and immediately saw a small piece of the door seal gasket was torn off. I will attach an image.
My main question is can this be patched (even if it won't be a perfect patch), by either gluing something to the gasket or to the door itself?
Thanks so much for any help you could offer.
P.S. What could have caused this?
post-2373-0-39777200-1380972307_thumb.jp
You can't patch it, you'll have to have it replaced. Even a hair or bit of undissolved detergent on the door seal can cause it to leak. It can be caused if a towel or other bit of laundry gets trapped between the door glass and door seal and gets pulled hard on spin.
You can order a new door seal here - 4Washerhelp spare parts
  • 1 month later...
