I have a bush A146Q washing machine.The internal door lock was broke so replaced it . Now my washer has another problem when select a wash a press the start button the program start and program end lights blink on and off at the same time . I've checked all connections bushes waste tubes and still have this problem . Any help or advise would be great full .
Here's a link to a 11 second video so you can see what I'm talking about , it happens on all the programs . https://www.dropbox.com/s/poju01cu2t49mxb/Video%2022-09-2013%2013%2011%2043.mov
Does it do the exact same if you try to run it with the door open? Sounds like maybe it can't detect the door is closed for some reason.
Thanks for the reply Andy
Yes it does the same . I've check filters water pump bushes ect . It's got me well puzzled because I've touched nothing I didn't take the top off to change the internal door lock .
What I'm getting at is if it does the same when the door is open maybe when the door is closed it isn't triggering the door interlock so the machine won't start because it thinks the door is still open. If it was OK before you changed the door interlock it has to be the main suspect. Check the interlock is on properly, wired correctly and that the door is closing properly and door catch latching into the interlock.
Ok after reading your replay I check the connection and the wires and all seem good, so I decided to ask my friend who has the same make and model as my washing machine if I could pinch his internal lock as his machine is working as you could guess he laughed but let me use it and I still get the same flashing lights . So I put my internal lock on to his machine and it worked fine . So I decided to take off the internal lock and try a program on my machine ( I know this sounds a bit bad ) but my washer told me that the door wasn't closed properly and I didn't get the program start and program finish lights blinking as before now I'm really confused .
That's a good friend :) Your logic is good, at least it shows the door interlock, the door, or its catch are not at fault, which has advanced things on. It's all about process of elimination. Unfortunately Bush is a none-make of washing machine which means they don't actually make them, they get someone else to make them and put the Bush name on. As such I have no technical information for them. It could be anything.
