andymp Posted August 2, 2013 Posted August 2, 2013 Hi. I have a Hotpoint WF860P washing machine. My problem is that the drum doesn't rotate. The washing machine does everything else fine. Starts, locks the door, fills up, heats the water, empties. But the drum doesn't rotate. I have consulted the FAQ's, The belt is ok, The motor is a 3 phase stator type, therefore has no brushes. The machine doesn't display any fault codes. Even with the belt removed, the motor still doesn't spin. I have tested the heating element, it is pulling 1.8kw, so that is ok. Are the brushless motors known to fail? or is there any way to test it? Or could it be the control board. Nothing looks burnt or damaged and the wiring looks ok Thankyou in advance.
andymp Posted August 3, 2013 Author Posted August 3, 2013 Turned out to be a broken wire in the wiring harness between the control board and the motor... sigh Whitegoodshelp 1
Root Admin Whitegoodshelp Posted August 5, 2013 Root Admin Posted August 5, 2013 Well done for finding that, it's unusual. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
