micky0121 Posted June 13, 2013 Posted June 13, 2013 Hi All Can anybody tell me if the thermistor on my machine could go open circuit , I took the heater element out and tested it , it worked ok , put it back in machine and will not heat water , I was thinking as I said open circuit ??. Unless you know better Thanks micky0121
Root Admin Whitegoodshelp Posted June 14, 2013 Root Admin Posted June 14, 2013 The thermistor should have varying resistances depending on the temperature. They usually contain temperature sensitive crystals which change electrical resistance at different temperatures. Therefore they shouldn't be open circuit but it's possible to go faulty, maybe one of the wires inside is no longer making a connection. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
