LewisClark Posted August 7, 2012 Posted August 7, 2012 Hi there. Just changed the heating element on a Hoover hnwl7136 washer dryer but it is still not heating up the water. Any ideas of what it could be?
Root Admin Whitegoodshelp Posted August 7, 2012 Root Admin Posted August 7, 2012 Is it giving an error code? Is it completing the cycle? Have you read this - Washing machine isn't heating up the water Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
LewisClark Posted August 7, 2012 Author Posted August 7, 2012 It's a basic model so I don't get an error code. It's does a full wash. I check the old heating element and had to change it as there was no current going through It. New ones is fitted and still not working? Or and I had a read of the links before I posted on here. Didnt seem to help
Root Admin Whitegoodshelp Posted August 7, 2012 Root Admin Posted August 7, 2012 Even the basic washers should give an error code, usually by flashing certain lights. If it's a Nextra model the pause and start LEDs should flash together a set number of times. 5 times is for "NTC/Heater fault" If it doesn't have any error code system in place then it would normally stick on wash if the heater isn't working. Is it completing the cycle in normal time and cleaning the clothes? What are the symptoms? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
