Showing results for tags 'waste pipe washing machine'.
  1. I have a slight leak from my waste pipe connection under the sink. The previous homeowner installed the kitchen and the pipes are different to what I've seen before. There is a grey pipe which sticks up and I've simply pushed the waste pipe onto that, as there's no other way to do it. Should I just fit a jubilee clip around the waste pipe, or do the pipes need changing to something more standard?
