HiFolks
I have a Miele W820 Washing Machine that's approximately 17 years old and is now not starting it's cycle (ie does not commence filling) on some Program Settings, but is ok on others. The machine starts correctly in the following positions:
- In the 'Cottons' programs the 70,80&90 deg C positions work (not 30,40,50&60)
- In the 'Minimum Iron' programs the 40,50&60 work (not 30)
- In the 'Delicates' programs only the Cold works (not 30,40,50&60)
- In the 'Woolens' programs only 40 works (not Cold & 30)
- None of Starch, Spin, Drain & Quick Wash programs work
They didn't all fail simultaneously & there seemed to be some indeterminacy when the failures began to occur (a few months ago).
I have taken out the electronic control module (ie the one with the Program Setting knob from behind the front panel) & cleaned the selector switch contacts with Deoxit (though you can't get to the inside of the switch, the spray would have penetrated) & have buzzed the contacts & it seemed to be ok. I'm assuming the problem is with this selector/control module, but the failure mode does seem odd.
Has anyone got any ideas on fault finding to help narrow the problem down? – I know there's another larger PCB behind the front section as I opened it up a few years ago to change the shocks. Has anyone out there got a service manual?
Thanks in advance
Gavin
