Showing results for tags 'sump hose'.
  1. My Bosch Classixx washing machine (WAE24164GB) developed a leak. On inspection I found that the sump hose had a small hole in it so I replaced it. After a trial wash it was fine but then started leaking again after that. Similar hole had been worn in the new sump hose in the same place. So I can only assume that it's rubbing on something but the hose seems in decent clearance - the nearest thing is a tie wrap on the drum?!?!? Anyone else experienced this type of problem. I don't want to replace the sump hose again until I get to the bottom of things properly. Any help gratefully accepted :-)
  2. My washing machine developed a leak. On inspection it looked like the leak was from the sump hose. Took the sump hose out and found a mangled metal filter. I am unable to find where this metal filter came from. Any help identifying this metal filter would be great. Thanks
