Showing results for tags 'machine not filling.'.
  1. Not a question, this is a result that I found that might help someone. I have the above washer dryer that wouldn't fill when a programme was started, the drum turned as if in a cycle. This would happen with any programme that I turned it onto. I was at my wits end and nearly was thinking of buying a new machine. I then remembered somewhere about resetting the machine memory by pressing the 'Start/Pause' button continuously. I watched the LED light cycle through green then amber then back to green again. When I started a programme again the water filled as normal. I don't know if this works for other makes of machine. So again: 1. With the washing machine on, press and hold the 'start/pause' button and watch the LED light cycle through green then amber then back to green again. 2. Start your programme as normal. I hope this can be of use to someone, I'm not sure if this is the right place in this forum to put this, or if this has been posted on this forum before, apologies if this is so.
