Showing results for tags 'fault lights'.
  1. Can anyone out there assist me with some information on what the following warning lights indicate could be wrong with my washing machine? I have 3 'beeping' flashing warning light (no digital display) that have come on and my machine will now not do anything. The first light that is flashing signifies the 800 spin cycle and the other 2 signifies the 'spin' and 'end' cycles. All 3 are flashing and beeping. I've cleaned the bottom filter and checked to make sure none of the hoses are bent or kinked. I've also taken off the bottom panel to make sure there is no water in the bottom tray (it is bone dry). Any one got any other advice on what to check next, how to do it or what those 3 fault lights mean flashing together?
