Showing results for tags 'error t3'.
  1. I am at wits end here folks. I don't know what to do about this washer i had to replace the back support spindle and finally got that done put the drum back together and the heating element was touching the drum reset that to where it ran through its little bracket and still the machine through the t3 code. I then replaced the thurmistor and still it throws the t3 code after waiting about 20 seconds. I don't know what else to do as all the code references from google searches say to replace the thermistor. I did and i know that bad parts come through but i would hope for $40 it wouldn't had been a bad part! PLEASE HELP ME i don't know what else to do! I can give you the model # if it helps also it is an american vs. of the machine!
