Showing results for tags 'drain filter'.
  1. Hi, I have Miele W2444 Washing machine that has started showing the Check Drain warning. I have tried to remove the drain filter with no success! I opened up the little door on the bottom left of the machine, turned the screw cap which let out about a pint or so of water. I continued to turn the screw cap until it came off and was left with just the screw cap. Most of the demonstrations show the drain filter attached to the screw cap. What is left behind the screw cap cannot be pulled out easily and I dont want to pull too hard and break something. I have attached pictures of the screwcap on and off. I guess my question is how do I remove the filter? and should the filter be connected to the cap? Thanks Peter
