please help, loaded my washer etc and started the cycle, the washer seemed to fill a little and take the detergent then when i looked the 'anti-crease' and 'door lock' buttons were flashing and the machine had stopped. I tried all the obvious turning on and off, checked filter and pipes but still wont work. the on off light comes on but the door wont lock and the cycle wont start, any suggestions??? thanks in advance
This article explains that this is an error code, but the names of the lights flashing aren't used to decipher - only the numbers of the lights (eg. Led 1 and 3 - or option lights 3 and 4)
Washing machine stops with lights flashing
That could be F10 error - "Pressure switch not sensing - check pressure switch and module"
It's a pretty general fault description not leaving much scope for non engineers to trace other than checking connections.
