Biggus Posted May 9, 2012 Posted May 9, 2012 Desperately hoping Andy is around to answer this! He seems to sort everyone out. Our dial seems to be the problem...selecting C or D, there is a noise like the programme is starting but thats it. No water, the drum won't fill and there's just a constant 'hum' as if it's trying to do something. If you turn the dial by a couple of millimetres then it will start to work properly...but then its on E which is the next programme!! So basically we don't have a programme that washes above 50degrees Help!! Thanks, Gus
Root Admin Whitegoodshelp Posted May 10, 2012 Root Admin Posted May 10, 2012 Hello Biggus. A humming noise could be the water valve trying to take in water. If yours is a hot and cold fill washing machine check out this help topic first Washing machine won't fill with water (or no water goes into washing machine) If it's only a cold fill washing machine then the fact that it fills on one programme but not another is less easily explained. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Biggus Posted May 10, 2012 Author Posted May 10, 2012 Hi Andy - thanks for taking the time to reply. The machine is a cold fill only. It's really annoying as we now can't wash anything over 50degrees. Any ideas? Or are we b*ggered? Cheers Gus
Root Admin Whitegoodshelp Posted May 10, 2012 Root Admin Posted May 10, 2012 I would check you don;t still have 2 fill valves. It's possible the cold fill is still spit over 2 valves and one is blocked or not getting enough water somehow. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
