My first post here, so hope i'm asking for some advice in the correct place - INDESIT WG113D. Has developed a leak at the rear of the drum, looks like it's coming from the tension bolt, this needs a large Torx head driver to tighten. Could there be a seal behind this that may have perished or should i just tighten up this bolt, does'nt seem to be any locking nut on this bolt, so it may have come loose after time? Any advice please, thanks.
Hello freedomrun. If it's the drum pulley bolt the drum bearing seal may well have failed. I have some tips on locating a washing machine leak here
