My Hoover Washer/Dryer VH W654 D appears to be working as advertised; however, at the end of each washing cycle, I have the error code E 07.
I read that this error code is indicative of a motor/drum/tacho fault. The drum appears to turn normally.
Is there anything that I can do to resolve this issue, or is it a job for a mechanic?
Thanks in advance,
Roxy
Hello Roxy: On the Hoover Nextra washing machine this error code relates to a tacho coil problem (Hoover Nextra error code 7) but on other Hoover washing machines it may not specifically relate to the tacho coil. However, they do appear to use error 7 to refer to faults on the motor though they usually refer only to non-specific general things like "motor fault".
If still under guarantee I would definitely get them out. Take a short video on your phone to show the machine displaying the error if it only shows at the end of a wash as an engineer won't have time to wait.
If it's not under guarantee you have to make a judgement call, maybe the motor could be over heating even? It definitely shouldn't be displaying an error code .
Andy,
Thanks.
I'll get Mrs Roxy to check.
I particularly like the bit about videoing the fault code turning up; I'd never have thought of that! Cheers.
Roxy
