Curious Posted June 5, 2006 Posted June 5, 2006 My indesit washing machine will sometimes not finish spinning. It is always on the final spin this happens, the program dial just starts clicking round. If it is left for a while you can restart it but you may get one load done then it will do it on the second one again. There is a fair bit of water left in the pump chamber located at the front of the machine is this normal? the suspension dampers have oil leaking from them could this cause this? If any parts recommended could you give a price of parts. Cheers.
Root Admin Whitegoodshelp Posted June 5, 2006 Root Admin Posted June 5, 2006 Most modern washing machines have replaced the manual timer with small electronic selector switches or control panels. These then simply start the the main controller unit which is a PCB which runs software similar to a computer. When a fault occurs, or is detected, it triggers an abortion of the program and should give some sort of error code. With these Indesit washing machines, the clicking programme dial is an indicator that the programme has aborted. It should be accompanied by either a flashing light or the illumination of one or more option lights. If there are no option lights then it should be the flashing light. It should flash a certain number of times followed by a pause, then the flashes repeat. ( Related: Program selector knob (dial) clicks round continuously It's also possible for low insulation on one of the components to trigger the dial clicking. You would need an insulation test meter to check the insulation of various components. Certain components (like the heater) that suffer low insulation readings or go "down to earth" can apparently cause this behaviour. The suspension can't cause any problems like this, it would cause excessive banging around on spin. The amount of water left in the filter chamber should only be about 2 - 3 mug full's of water. If there is more, it could be it isn't emptying the water fast enough and this would cause an error like this (check the pump filter - How do I clean my pump filter - where is the pump filter? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted June 5, 2006 Author Posted June 5, 2006 I have a little more to add. It is ready to go into a fast spin 1000 rpm when it stops and the pump seems to come on and while it is clicking around the pump is still trying to pump water away. Should it even be on during final spin? Great site by the way!!! I live in Fife Scotland if you have any telephone numbers for reputable washing machine engineers.
Root Admin Whitegoodshelp Posted June 5, 2006 Root Admin Posted June 5, 2006 Cheers. The pump should be running on the spin program from start to finish. If it does it only when reaching spin, then presumably we can discount the heater being down to earth as that should cause problems virtually straight away. Therefore it may be something involved with the spin procedure at fault. If you are looking for a reputable washing machine engineer, here's a link to a post code search form where you can search for a washing machine engineer by post code area - Search for a washing machine engineer Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted June 5, 2006 Author Posted June 5, 2006 I have just noticed there seems to be a leak from the back of the drum, it is dripping down on to the motor. It's not a bad leak, but it may be enough to do something to the motor. This is probably why when I leave it overnight the first wash seems to be okay then it struggles from then on. Obviously the motor has had time to dry out. It also started to do it when trying to start programs when I was trying one after the other. Thanks for your help any other suggestions are welcome but I think I may leave this to the experts, or get a new washing machine.
Root Admin Whitegoodshelp Posted June 5, 2006 Root Admin Posted June 5, 2006 It does sound like it's something you need to get an engineer to sort out if you can't see the source of the leak. It could be the motor that's going down to earth. Not enough to short out but enough to send the controller funny. This is one of these faults that only when someone experienced (and honest) examined the washing machine will you know if it's worth having repaired or not. The motor could be OK once dry as long as the leak is stopped. Unfortunately though, on these cheap washing machines, if you needed a new motor it could easily cost £150 - £170 which is ludicrous. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted June 5, 2006 Author Posted June 5, 2006 It seems to be leaking from the back of the drum. There is a metal strip that goes right round the drum with a big bolt to tighten it up. Is there a seal inside there that may need replacing? I tightened the screw just slightly and have had four successfull washes, but there is still a little water coming out. This is not enough water to run round the bottom of the drum and drip around motor area but after cycle is finished if you wipe around the metal lip there is a little water seeping out of it. Anymore help would be appreciated. Thank you again.
Root Admin Whitegoodshelp Posted June 5, 2006 Root Admin Posted June 5, 2006 Before getting too involved in fixing the leak, did the washing machine work OK with the reduced water escaping? In other words are you confident that the leak is the source of the not spinning problem? The seal you require should be available from here - Appliance spare parts (4Washerhelp) Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted June 5, 2006 Author Posted June 5, 2006 I'm certain it is the problem as there has been no more issues since stopping the leak, but I do think it will gradually get worse again unless fixed. Fitting instructions will also be required. Thanks for all your advice it has been very helpful. We have now caught up with the backlog of washing.
