GOT BEKO WASHING MACHINE MODEL WMB 71442W ON 7/4/2012 FROM DAY ONE WHEN IT SPINS IT SOUNDS LIKE ON OLD OUTBOARD MOTOR CUGGING AWAY IS THIS NORMAL
Doesn't sound it. The pump can be pretty noisy these days when it's pumped out all the water and is pumping mostly air. But if the noise only happens on fast spin it may be related to bearings. If the pump makes a slurping pulsing noise, which you can hear when the drum stops turning during rinses and before and after spin then it sadly is quite normal these days with a lot of brands.
