ninereddogs Posted April 6, 2012 Posted April 6, 2012 Hi all, Newbie here, opened up my condenser dryer to find my belt had got mangled around the pulley assembly. Damage has been done to the pully - so need to replace it and i'll do the belt at the same time. Has anybody out there got some tips for me - looks tricky to remove the pulley - as the extractor fan unit connected to the motor spindle is in the way. first attempt appears tricky to remove the extractor - have removed locking nut - but still a bit stiff - didnt want to yank it and break something else -so any tips here ? also just wanted to check that there's only a single pulley on these dryers i.e. no idler pulleys - the main pulley got pretty damaged - so not sure what other parts got broke behind it. The reason i ask, is the belt has plenty of slack - so its probably got stretched - but i just wanted to check. Any help very welcome. Dogs
Root Admin Whitegoodshelp Posted April 7, 2012 Root Admin Posted April 7, 2012 Hello and welcome. Unfortunately your question is about a tumble dryer and there's only washing machine forums here. I would advise that replacing a belt on a tumble dryer is a lot more involved than doing the same on a washing machine though - Tumble dryer runs but the drum doesn't turn Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
