Hi, I'm new to this so bare with!
Our Bosch Classixx 6 has been moved to an upstairs loo which we have converted to a utility room - the loo feed now feeds the machine.
We had a problem with the machine not filling but on removing the small black rubber grommet from the inlet feed/filter there is enough pressure to feed the machine.
Great......but.......we now have a problem that the water appears to continue to run into the soap dispenser into the machine.
I have read through all your info on siphoning and I am certain that this is not the issue as I have placed the waste well above the drum level.
Does this model require a higher pressure feed that in turn activates an internal 'switch' or valve that stops the flow from the supply?
Thanks, Mark
Hello Mark. I suspect the water pressure isn't strong enough to close the valve. I have a topic covering this on my Blog - Low water pressure and washing machines
Also check out this article for other possible causes of washing machine filling with water when switched off
Hi Andy
Thank you so much for replying so quickly!! :D
From what I can glean from your very thorough blog I suspect my only option is to replace the machine with one that can operate (fill) and close the valve at a low pressure.
The cost of running mains to this part of the house or installing a pressure pump would probably be the same as a replacement machine?
Thanks. In my blog article I mention that Electrolux, AEG, Zanussi washing machines claim to work on only half a bar. However, do you have half a bar? 1 bar is a pressure thats capable of supplying water 10 metres high so although not an expert in water pressure I would assume half a bar should be capable of supplying water up to 5 metres high or at least capable of filling a pipe 5 metres high and coming over the top.
