After the last wash, machine has filled up with cold water - but not above the bottom of the door - and now won't drain.
There isn't an LED display so there's no error message.
When I want to start a cycle, the 'door locked' light flashes red repeatedly (not in a pattern ie. 7 times).
I've read some of your forum and I think I need to take out the cold water lead (from top right-hand corner of back of machine) and make sure it's not blocked, should I do this?
Please help, I know very little about this sort of thing.
I've already put all the advice I can think of do deal with a washing machine not emptying the water (including how to drain it). I would drain out the water using the advice in my article.
If by any chance the washer has filled up with water without being on a programme there are a couple of explanations here - Washing machine fills with water overnight or when switched off
If the article and all the other relevant ones it links to don't help I would suggest getting an engineer.
