andy67 Posted January 30, 2012 Posted January 30, 2012 hi , i have a candy washer/dryer as soon as i press start it trips electric , ive narrowed it down to the motor . the brushes look ok ,but if i disconnect just the brushes it all works ,and trips as soon as reconnected. is it brushes causing a spike to trip elec,ie: would a replacement set do the same ,or is it a more serious prob with motor? any suggestions greatly recieved
Root Admin Whitegoodshelp Posted January 30, 2012 Root Admin Posted January 30, 2012 Washing machine is fusing, or tripping the electrics This fault can't be diagnosed without an insulation test meter. The chances are the armature or field coil are "down to earth" and have an electrical path to earth. It's possible for a build up of carbon dust to cause it so you could always try blasting it with one of those air duster cans designed for cleaning computers on the off chance of dislodging it but these days they are designed in ways that make it more rare for carbon dust to build up inside. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
andy67 Posted January 30, 2012 Author Posted January 30, 2012 excellent , just had motor apart and blown out with airline , ive attatched it to machine and no tripping!, now to run it up to speed under load and fingers crossed its sorted thanks for your prompt reply
