Hi, if anyone is willing to offer their opinion on my enquiry I would be very grateful please.
I have a Miele W844 which is 10.5 years old. An engineer has been out today (from the list of approved repairers as Miele have engineering shortages in my region) and has said the Control Board is at fault. Taking in to account the part and labour, the cost will be £400ish to repair it. The engineer said he believes it is worth doing as the machine is in excellent condition but I have a niggle in my mind of whether this is worth doing. I have seen the blog about costs being relative to replacement and agree with the sentiment that expected life cycle is only relevant if a repair of this value is undertaken.
Fault was lights on display were flashing but, of late, with fuller loads, the machine seems to have "jumped" occasionally but the engineer says all shock absorbers etc are good. Bit puzzled how this
might still happen as finding it hard to link that to a failed board.
Would consider W5740 as replacement at £830 so is 50% of new cost worth considering?
Thanks,
Tinkle
Many thanks,
Tracey
Miele washing machines are designed, built and tested to last at least 20 years. So in theory your Miele is only half way through its life. It should be worth repairing even at £400 because you may get another 10 years or so out of it.
If the W5740 you mention is an equivolent, and replacement cost is £830 then spending £400 on a machine with another 10 years potential still makes sense. On the other hand, if there is an equivolent model available, which more matches the features on yours but a lot cheaper then the scales tip more in favour of replacing it (eg, if you could buy a similar spec one for say £590).
It's a close call, and there's no perfect answer. A lot depends on your attitude and willingness to replace it at £830. I would say if you are flush, and fancy a new one fair enough but if it's pretty inconvenient right now to spend £830 it might be worth gambling on getting a few more years out of the Miele. The main worry I have is the cost of repairs for Miele appears to be getting out of hand.
Hi Andy,
Thanks for the reply and I am sorry for the delay in responding.
Actually had the engineers back out as they were puzzled by the first diagnosis. Different guy soldered in new fuse and replaced a relay,which was what I had told the first guy seemed to be a reported error from researching on web. So, it is working again but had jumped around when washing two bath sheets, one hand and one foot towel. Works fine on all other loads. Engineer agrees that towels do not go over load capacity so everyone is puzzled now!
For me, the sign of a good company is how they respond when something hasn't gone well and these guys were very keen to follow up and set things right.
Think we will see how it goes but will buy new if the fault reoccurs.
Thanks again,
Tracey
I agree very much that the sign of a good company is not whether things go wrong or not but how they are handled afterwards. We all make mistakes and we all cock things up at work from time to time. Towels are notorious for jumping about and usually when there isn't enough of them in or there are just a few of them mixed in with other lighter items rather than being too many.
I can't say under-loading is causing the issue, but it's worth looking at this article so you at least have an idea of how under-loaded towels can cause balance issues - Bangs on spin: How do I avoid out of balance loads in my washing machine? (Having said that, Mile's out of balance system is supposed to prevent out of balance loads spinning.
  • 11 months later...
A couple of things: I was looking for a baby guide to shock absorber replacements.... everywhere it is said that it is "easy".. but none of the descriptions of the work that I read were complete. So, this is my attempt.
First, our W820 has no bottom plate, so access is possible through the base, contrary to what was written above: BUT, you might not need it.. read below.
The steps are as follows:
1) Open the washer door. Turn off and disconnect the power.
2) Remove the top: To do this, take out the two plastic screw covers on the left and right of the top and undo the screw. (Crosshead). The top can be hinged backwards and then lifted off.
3) Inspect the drum. Push it up and down; if it bounces more to one side then that is probably the location of the faulty shock absorber. It is good practice to replace both shocks at the same time. However in our case a repair man fixed just one ! a year ago and the bouncing showed that the shock on the right was faulty.
3) Remove the washer front panel. You do this as follows:
a) Remove the soap drawer and put it to one side, pulling it forwards and depressing the red plastic lever visible towards the rear of the drawer. This allows it to be slid out.
B) Remove the three star-headed screws holding the soap drawer surround in place (I used Allen screw drivers for this.. not good I know).
c) Open the panel used for draining the machine (front panel, bottom left) and unhook the plastic drain pipe which clips into the door.
d) Remove three 10 mm bolts from the front panel. These are around where the wash door would normally close (I hope you left it open from step 1)
e) The front panel can now be hinged open (hinges on the right) and you should be able to see inside. Take the opportunity to clean up any visible mess.
4) Inspect the shock absorbers. The right hand shock is visible through the bottom right of the front of the machine. It is a metal cylinder about 6" long fixed at an angle. The left shock is visible but hard to access from the front.
5) In our case we only need to replace the shock on the right. You need a 13 mm ring spanner and you can do the removal entirely from the front... without even moving the machine. Undo the bolts at the top and bottom of the shock and pull it out. Inspect it for confirmation of fault. In our case there was NO resistance to movement at all. If it looks to be in good condition then it is probably the other shock causing the problem. In any case replace both.
6) The left-hand shock needs the machine put on its side for access through the base. Put down some cushioning material, blankets, heavy cardboard, etc to protect the sides and gently tip the machine. Ideally this is a two-person activity. If not, be careful! Again, with a 13 mm ring spanner unbolt and replace the faulty shock.
7) How tight should you bolt the shocks.. as tight as you can with one hand. The machine is robust.. but breakages can occur if the ring spanner slips and hits wiring or connectors, so ensure that the spanner is always fully home on the bolt head and wiring pushed out of the way. I protected my hand from spanner slippage by wearing a gardening glove for this part of the operation.
7) Now all we need is to reassemble:
a) First close the front panel and bolt it shut with the three bolts around the door. These take the strain and should be bolted first.
B) Then we put back the three screws holding the surround for the detergent drawer. Don't over tighten.. it just needs to be firm, not rigid.
c) Reattach the drain plug to the door of the access panel (bottom left) and close it.
d) Lastly, replace the top of the machine, attaching the rear of the top first and hinging downwards, and then use the two screws and plastic screw head covers to complete the job.
You should now have a working Miele with several more years left to run.
When we bought our first Miele (in Holland) it had an expected lifetime of 20 years according to the store. It survived for 20 years, surviving moves across 3 countries. We then tried Hotpoint.. total rubbish and it died after 3 years. We are now on our second Miele and it is around 17 years old and, with this repair, working perfectly. Perhaps one more will see us into (and out of) retirement. In the meantime, it is worthwhile keeping these excellent machines in good condition. They are not throw-away!
Read more:http://www.diynot.co...1#ixzz2HSvaDRbA
  • 5 years later...
I just replaced the shocks on my 12 (or more) Meile W865. The old ones were completely shot and the drum bouncing all over the place. It was pretty straight forward but a socker set with extensions was useful. After replacement I pushed down on the drum and it barely moved. They should have been replaced long ago. Perhaps more modern machines tell you when to replace them, say after X number of cycles. I would certainly reccomend testing your own machine and replacing them if needed.
  • 1 year later...
Another episode in the Miele W856 saga. The fuse on the control board blew and blew again when replaced. I took a look at the motor and checked the brushes which were almost perfect (this machine is 15 years old, I was amazed). I checked the reversing relay and sure enough there was around 5 Ohms across the pins which were closed contacts. Replaced relay and fuse and all is well. Hopefully I will get many years out of it yet! I am going to keep a spare relay to hand.
