stuartm25 Posted January 17, 2012 Posted January 17, 2012 I have contacted various suppliers of Bosch spares who tell me that the retaining bolts and the rubber washers/ spacers that hold the concrete block (that comes as a kit) is obsolete and no longer available. The block is loose and bounces around. I believe that the same construction was used for a number of machines. Seems a shame to scrap the machine for the want of some washers. Is there something I can do?
Root Admin Whitegoodshelp Posted January 17, 2012 Root Admin Posted January 17, 2012 How old is the washing machine? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
stuartm25 Posted January 17, 2012 Author Posted January 17, 2012 It's somewhere between 8 - 12 years old. I'm sorry I'm a bit vague.
Root Admin Whitegoodshelp Posted January 17, 2012 Root Admin Posted January 17, 2012 Manufacturers are obliged to keep functional spares available for so long. It used to be 10 years but I think many have reduced it to something like only 7 as the life of their products has so obviously declined. Have you tried tightening the nuts up and putting loctite on them? If they are obsolete then you can't do anything unless you managed to find a scrap one somewhere or someone with old stock they are glad to get rid of. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
stuartm25 Posted January 17, 2012 Author Posted January 17, 2012 I have tried remedial action that did not work. However, I have just rung Buy Spares (I have only recently found your site) who have identified the parts and said that it is available (although as a special order that it could take up to 28 days). However, I have now discovered that the metal 'lug' or protruding strip through which the retaining bolt secures the concrete block to the drum has sheared. Mmmm. I think this means a welding repair but I don't know whether this is feasible. Anyway thanks for the advice.
Root Admin Whitegoodshelp Posted January 18, 2012 Root Admin Posted January 18, 2012 Most modern washing machines have plastic tubs, when the weight comes loose, which is far too common, if not fixed straight away it often results in the tub brackets breaking away, which is then scrap. It requires either a new tub or new machine. Anyone hearing a knocking noise every time the washer gos into spin should not ignore it. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
