I have an Indesit WITL-105 washing machine which I bought 2 years ago. When the technician installed it he said that the filter is behind the plastic cover at the bottom and it needs to be changed every few months. When I later opened it I didn't find a filter that can be changed, only a cap that's screwed in.
A few months ago (for the first time) the washing machine completely shut down during a load of laundry. All the lights turned off and I was able to open the lid. It turned out to be full of water so I unscrewed the cap at the bottom and it drained a few gallons of water. The cap had no dirt or anything clogging it. After draining the water the washing machine was functional again. The same thing has happened 3 more times since then.
What is wrong with the washing machine? How can it be fixed?
Nothing needs replacing every few months, the pump filter needs checking (ideally) every several months or so but in practice most people don't need to check it and just clear it if it gets blocked. Read my article on how to deal with a washing machine not emptying water which also contains links to full pump filter guide.
It could be that your washing machine's pump has an intermittent fault, or there's some other intermittent fault causing the issue. Or possibly small obstructions that are either getting flushed out when you drain the machine or even floating back out of the way up the sump hose only to eventually find its way back into the pump again.
Intermittent not draining faults can be tricky to diagnose. When it stops emptying you have to try and assess whether the pump is running, or jammed (often with a gentle humming noise) to get an idea what the problem might be.
