t111drs Posted January 2, 2012 Posted January 2, 2012 Hello I have a old hotpoint 9518P which won't turn the motor any more. The timer turns and clicks, but the drum motor will not turn, the pump motor does work. I have checked the motor brushes and they are not worn out yet, I replaced them about a year ago. the brush contacts on the inner motor coil look ok no visable damage. I tested the resistance of the motor coils, approx outer 3ohm's inner 4 ohms (inc brushes). I tested the connecting cable and is looks ok with the multimeter. I tested the controller output 40v ac to the inter coil and 26v ac to the outer coil. The controller is a reverbed one this summer. does any one know what is wrong here? I don't want to spend £150 on a new motor when is the controler under warenty. Thanks for looking. Paul S
Root Admin Whitegoodshelp Posted January 3, 2012 Root Admin Posted January 3, 2012 You've checked as much as you can. The only thing left now is to guess at what part may need replacing, which I wouldn't advise doing. It's only what most engineers would do after checking all the things you list anyway except they mostly have access to the parts to try. You can't rule out the possibility of a rare broken connection or wire somewhere. I've even had them where the wire looks perfect but the copper wire inside is broken. As I say, after doing all those checks most engineers would just try a new pcb or motor and hope it fixes it. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
t111drs Posted January 6, 2012 Author Posted January 6, 2012 Hello Thanks for te reasurance I have tested all I can, spoke to one of the electical eng at work and he seemed to think I had done all i could. so I will start with the contoller. Thanks Paul S
Root Admin Whitegoodshelp Posted January 9, 2012 Root Admin Posted January 9, 2012 A pcb can easily be over £100 and there's no guarantee it is the culprit. Even if it appears to be the most likely culprit I personally would not gamble that kind of money without knowing it is definitely the fault. Check out what Hotpoint would charge to fix it, they have fixed price repairs now, which may not be much more than the cost of the part. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Root Admin Whitegoodshelp Posted November 7, 2013 Root Admin Posted November 7, 2013 Some more help here for troubleshooting drum not turning Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
