The machine goes through a wash cycle but will not spin. I have tried selecting the spin only function with no clothes loaded but it still does not spin. I checked the motor brushes and although worn they seemed ok. I renewed them anyway. I have removed the rubber tube from the underside of the pressure switch, but no "click" was heard. Tried spin cycle with the rubber tube removed but no difference. Any more suggestions?
I would say you've done all you can to be honest, and pursuing it further is likely to involve guess-buying a part, which may or may not work.
  • 1 year later...
I now have a full article which gives a lot more advice on this subject - Washing machine not spinning – or drum not turning
