hi my bosch exel is leaking water badly from the back of the machine i have had a look behind the inspection panel its running down the back of the big cast alloy belt drive ive had a look under the top cover and can see no leaking pipes however i found the two screws that keep the dispenser from rattling about at the top of the machine had fallen out and i have replaced these and solved the awful knocking that this produced has this caused my water leak cheers stuey
Sorry Stuey, without knowing where the leak is actually coming from no one can say. With leaks you have to find exactly where it's coming from or see the evidence maybe from trail marks. If it is the cause of the leak you should be able to see where something has worn away or come loose.
  • 1 year later...
I've now got a comprehensive set of articles looking at washing machine leaks starting with 5 tips for finding a washing machine leak. This article gives 5 tips but also links to more specific leak problems at the end.
