Can anyone tell me how to access the PCB on a Beko WMA 510W machine?
The fault is :- It started being unreliable at spinning on the main cycle, then it was unreliable at spinning on the rinse and drain cycle. Now it just takes in water, rotates for about 5 minutes, then stops, leaving me with dirty, soap slimed soaking washing! I think I need to change the PCB, but can't see how to access it.
I hope not to offend but I if you don't even know what a part looks like or where it is it might be better not to try and replace it. You cannot get guarantees with parts such as the pcb because they are so often misdiagnosed as the culprit so it would be a speculative gamble replacing it because it's not certain to be the cause of the fault.
