macg29 Posted September 26, 2011 Posted September 26, 2011 Engineer is flumoxed machine works perfectly ......with nothing in it !! it jams at 38 on a 30 degree wash then 14 on a quick 30 it basically will not spin . no fault codes coming up tried switching it on and off and had the weight thing replaced .....still the same ?? machine cost a lot of money so any ideas anayone
Root Admin Whitegoodshelp Posted September 28, 2011 Root Admin Posted September 28, 2011 LG are one of the companies with very little technical information available to independent engineers. It doesn't sound like a straight forward problem. If the engineer is not an LG dealer you may need (will be forced) to use one. If he is, he shouldn't be flummoxed, or at least should be able to get to the bottom of it with help from his manager or tech support. I have some general advice here - washer sticks mid-cycle Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
