I have a Bosch ClassixX. It has a front panel with four push button switches for different functions grouped together and one push button start switch slightly to one side. The start switch has been playing up for some time, requiring a particular type of 'push' to make it work. Now, it won't work at all. I'm not sure if the fault is mechanical or a dodgy electrical contact within the switch. Does anyone know if I can buy a replacement switch or whether I will have to replace the entire panel?
If it's a proper switch you should be able to replace it separately but if it's a small button which is part of the control panel it will need a new control panel/ Try here to see if you can see the part - 4washerhelp spare parts
