rammy71 Posted September 7, 2011 Posted September 7, 2011 Hi,I have a Zanussi ZWX1605W ,the machine will not go into cycle and take it water ,just runs the pump continuously.If you advance the programme it will take in water on the rinse section and drum will move back and forth but if you advance to the spin cycle it will drain all the water and run drain pump continuous and not spin
Root Admin Whitegoodshelp Posted September 10, 2011 Root Admin Posted September 10, 2011 It could be an insulation fault but an insulation test meter would be required to test it. If any lights are flashingit could be indicating an error code, which would be better for diagnosing but it sounds like it needs looking at by an engineer. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
