su966 Posted August 24, 2011 Posted August 24, 2011 Whirlpool washing machine: Model w120 Motor: CESET MCA52/64 - 148 IRN1 7 Pin connector Pin 1 : Yellow, Pin 2: Grey, Pin 3: Black - These three pins shows continuity to each other. Pin 4: Blue, Pin 5 : White, These two pins shows Continuity to each other. If I disconnect one of the carbon brush connector then no continuity between pin 4 and 5 Pin 6 and 7: RED, they shows continuity of 4 ohms. I do not have an insulator tester. How can I test if the motor is OK using an analogue multimeter ?
Root Admin Whitegoodshelp Posted August 24, 2011 Root Admin Posted August 24, 2011 The three that show continuity between them are probably the field coil. Pins 4 and 5 sound like the carbon brushes and armature The other two (will usually be much thinner) sound like the tacho coil. If you are getting continuity between them all they are likely to be ok, at least in the sense that the motor should at least try to run. You can't test for insulation safety without a specialise insulation test meter (megga). If the brushes are ok (neither of them burned or charred) and the continuity tests ok with a multi-meter it would suggest the fault may lie elsewhere and I would get an engineer to be honest. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
su966 Posted August 26, 2011 Author Posted August 26, 2011 I called an engineer and he told me that it is the timer. Its not worth repairing. Time to get a new machine.
Root Admin Whitegoodshelp Posted August 26, 2011 Root Admin Posted August 26, 2011 Thanks for the update Tabby. Many people don't take the trouble :-) Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
