hiii, i just moved in a new house and here we have an old washing machine and i don't know how to use it. The model is HOOVER ELECTRON 850WD please if you know how to use it, this information will be usefull. thank you very much
  • 3 weeks later...
Hi there,
Hopefully I can help.
Firstly, congratulations - the Hoover Logic/Electron range are some of the best, and a darn sight better than 80% of the modern market.
They use the old timer-style controls, which means the programs will be set our in order around the program selector. The rule with these style machines it that program 1 (or A if the machine has letters instead of numbers), is usually the hottest, longest wash and the programs follow on as below:
1/A - Whites 90/95 with pre-wash
2/B - Whites 90/95
3/C - Fast Coloureds 60
4/D - Non Fast Coloureds 40
5/E - rinses
6/F - Spin
As this is an older machine, it won't have a 30 degree cycle, but it will do a full load on Non Fast Coloureds 40 or 60 in an hour or under. You should be fine using these 2 cycles (40 for darks and coloureds and 60 for whites and bedsheets) for pretty much everything.
Hope this helps
  • 2 years later...
I have a page on my main site to find instruction books and manuals for washing machines and other appliances.
