bevy25 Posted August 1, 2011 Posted August 1, 2011 hi i have a point wm52 it keeps putting black marks all over my clothes was told 2 run calgon thru it on a boil wash also had the filter checked made no difference anyone got any ideas please
blueboy2001 Posted August 2, 2011 Posted August 2, 2011 The most likely cause is that the rubber bearing seal has failed. This allows water into the bearings which will wash the grease out and it gets drawn into the tub and onto the clothes. You will really need to have the bearings and seal replaced. This is quite a big job - at least 2 hours labour for a pro and all day of a job for a DIY'er with the correct tools.
Root Admin Whitegoodshelp Posted August 3, 2011 Root Admin Posted August 3, 2011 If the washing machine is noisy on spin then drum bearings could be the issue as blueboy2001 mentions. If the door seal is covered in black mould maybe it could be the problem.There are some general points worth looking at in these links -Washing isn't coming out clean or has marks on it (Last article at bottom of page) Whites coming out of washing machine looking grey, coloureds losing their colour Grease marks or spots on laundry White streaks or residual washing powder after washing Washing not getting clean Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
