If the belt is coming off but the condition of the drive belt is ok then the drum pulley is most likely to be running untrue. This can be caused if the drum pulley has worked loose, or the drum bearings may be worn. If you can lift the drum up and down from the front behind the door and can observe that the drum pulley moves quite a lot this would indicate they are worn. I would also expect it to be noisy though.
  • 2 years later...
I now have a full article on the causes of a drive belt which keeps coming off
