GeeDee Posted July 3, 2011 Posted July 3, 2011 HiOur Bosche WFF2000 tripped our main RCD at the end of a wash (door lock had released) and now is permanently leaking live to earth. I have tried disconnecting the motor with no change so am guessing the issue is eleswhere.Whilst I'm normally happy to have a go at most things, this seems a little complex without the necessary equipment or going round unplugging everything using trial and error.Is anyone aware of anything obvious (and relatively simple with just a multi-meter) to check?My feeling is that is is getting on a bit and needs replacing.
Root Admin Whitegoodshelp Posted July 4, 2011 Root Admin Posted July 4, 2011 As you say, to troubleshoot a pcb tripping fault you need a proper insulation test meter capable of putting 500 volts (DC) through the machine. The most common causes of a washing machine fusing or tripping the electrics are mentioned here - Washing machine is fusing, or tripping the electrics Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
