Hi all, i am a catering equipment enginner and have a problem at home with my washer drier. Due to the fact that i fix equipment all day the wife thinks i should be able to fix everything in the house as well.
My washing maching has, what i belive to be a fault code???
lights (from the left) 1, 2 and 4 are flashing. the door lock light is also flashing but twice as fast.
Would be greatful if anyone could help. Im moving house this weekend and not looking forward to a big expensive repair!!!
Dan
The information I have is that on an Indesit washer dryer, the first, second and fourth lights flashing indicate error code F13, which is "Drying failure: Drying NTC failure or possible motor fan jammed". The NTC is a thermostat filled with temperature sensitive crystals.
There is a little more (only general information) about NTC's on Washerhelp Search for NTC
General advice on washing machines with lights flashing
