Curious Posted May 26, 2006 Posted May 26, 2006 I have a hotpoint aquarius 900 WM61 brought from new in 1997. The washing machine has never been a problem up until a few months back when it would stop working and not spin the clothes. I rectified this problem by putting in new brushes as the old ones had completley worn down in the motor. Everything was fine up until the middle of last week when I noticed that the machine (I took off top cover whilst on) was sparking heavily from the motor (especially on long spin) and at one point even tripped the electicity switch at home and cut out our electric. I took out the brushes and they had melted the plastic at the base of the brushes where they had been sparking badly. I took them out and replaced them with new ones again and put on a wash. They were still sparking but very minor from where the brushes meet the armature. The only problem is that I am getting bad sparks from (appears to be) inside the armature. Sometimes you can smell the motor burning and will cut out on a high spin or will not spin as much as it should do and hence not clear the water from the machine (very soapy suds). My question is, as the motor is 6 years old now and with 2 children it does takes quite a pounding, do I need a new motor? Any help would be greatly appreciated as the washing is already piling up!
Root Admin Whitegoodshelp Posted May 26, 2006 Root Admin Posted May 26, 2006 If you are fitting the brushes correctly, and getting excessive sparking, it's likely to need a new Armature. Fitting an armature would make the motor as good as a new motor, because once replaced, all moving parts inside the motor are new. However, these days it's rare for a washing machine armature to be available as a spare part, many supply only a replacement motor. If you continue to run the washing machine, it may well blow the TOC in the field coil or damage the main PCB. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted May 26, 2006 Author Posted May 26, 2006 Many thanks for you reply. Can you advise why the brushes I took out had melted, and the new ones I had put in have started to do the same. Is this to do with the armature on its way out? Could I have put the brushes in wrong? I thought it just a case of popping them back in, they can only go in one way! Also the TOC in the coil field - What is this? Once this has gone I take it the motor will stop altogether. Thanks
Root Admin Whitegoodshelp Posted May 26, 2006 Root Admin Posted May 26, 2006 It's the sparking that causes this burning. You are right to say they won't physically go in wrong on these motors, but the brushes are held retracted inside their holders (for protection in transit) and so there are some potential problems. When fitting them, you need to prize away the little tab on the brass bar at the side so that they are released. Two possible problems associated with this are - releasing them before they are inserted into the motor not releasing them at all, or not releasing them properly Releasing them before inserting is OK, I sometimes do it myself, but with the brush sticking out it's possible for a brush to ride over the armature when inserted, or even snap, which causes excessive sparking and premature failure. (it doesn't sound like this is your problem though) The second problem is to do with the little tab holding the brush retracted inside its holder. If this isn't prized fully away, then although it releases the brush, when the brush is inserted into the motor and butts up to the armature, as it naturually pushes back inside the holder it can stick there. Then, when the first millimitre or so of brush is worn away after several washes, the brush (which is spring loaded and pushing against the armature) can't move up and you get sparks jumping across the gap. It can cause the plastic on the brush holder to melt and failure occurs. Take the brushes out and double check that the brushes move freely in and out of its holder. Another possible explanation for excessive sparking like this is if there's a partial blockage in the sump hose causing the pump to be unable to empty enough water out, but allowing enough out to go into a spin. The washing machine can then start spinning with too much water inside which puts it under strain. The TOC (thermal overload cutout) will blow if excessive sparking or slowing of the armature causes the motor to overheat. It's replaceable on older Hotpoint motors, but a further unwanted complication and expense. As you guessed, once blown the motor will go dead, but of course a dead motor doesn't necessarily mean the TOC's gone. To test this, you need to test continuity between the blue wire from the brush and the tag on the motor and the yellow wire from the brush to the ajacent tag in the motor. Related: Hotpoint & Creda carbon brushes FAQ (diagnostics and fitting advice) Fitted Hotpoint or Creda carbon brushes and motor still doesn't work Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
