Andy, in an earlier post you advised that the drum belt rarely jumps off the drum pulley unless there is a contributory reason. I can confirm in my case this was due to the failure of the inner drum bearing. This means that the inner drum no longer runs concentrically with the outer drum. I now know the real source of the banging noise - not the detergent ball as originally thought.
How likely can this be repaired successfully by replacement of the drum bearings alone, or is the damage probably more extensive and possibly a new drum assembly will be needed?
In which direction do you withdraw the drum to remove the bearing? Through the back, front or top?
The washing machine is about seven years old.
Grateful for any advice.
Many thanks.
This is a common problem with Hotpoint washing machines and one that's still affecting new models today. It's only a DIY job for the confident - or someone who enjoys a challenge.
If the front drum bearing has collapsed (which it often does, and can be detected by a lot of up and down play when lifting the front of the drum) then you may find it impossible to get the front drum bearing's outer race out of the tub without a special bearing removal kit. It's possible for there to be a fair bit of play without the front bearing having collapsed, but occasionally when you try knocking it out, it still collapses.
You'd need to replace -
  • the drum shaft spider (which bolts to the drum)
  • the front drum plate seal
  • both drum bearings and the bearing seal
All these parts can be bought directly here - Washing machine spares
Troubleshooting washing machine belt keeps coming off
Andy. Thank you for your excellent advice. Forums such as yours show what a force for good the internet community can be. Again many thanks.
