Tozza Posted July 30, 2025 Posted July 30, 2025 Hi I've been plagued with the dreaded E18 fault on and off for a while on my Bosch. I drain it down and pull the filter out and sometimes theres slivers of loose limescale in there and removing them fixes it. Other times I've just turned it off and back onto a short cycle and it has drained OK. This time I had a really good look with the filter out and there was a load of hair behind the spinny thing in there so got all that out with needlenose pliers. Thinking that this time I'd cracked it and given my machine a new lease of life, especially after the first wash drained away without any problems, wash no.2 brought up the same error code. I drained it and must have been 10 litres came out - I don't remember having that much left in there in the past. There's no blockages in the waste plumbing. Does it sound like I need to replace the drain pump? Is that a common fault? Reckon we've had the machine well over 5 years now. Pump doesn't seem to be expensive but is there anything else I should check first? Should the spinny thing spin freely? Mine needs a bit of pressure and feels lumpy to push round. Would appreciate any wisdom!
Tozza Posted July 31, 2025 Author Posted July 31, 2025 11 hours ago, Tozza said: Hi I've been plagued with the dreaded E18 fault on and off for a while on my Bosch. I drain it down and pull the filter out and sometimes theres slivers of loose limescale in there and removing them fixes it. Other times I've just turned it off and back onto a short cycle and it has drained OK. This time I had a really good look with the filter out and there was a load of hair behind the spinny thing in there so got all that out with needlenose pliers. Thinking that this time I'd cracked it and given my machine a new lease of life, especially after the first wash drained away without any problems, wash no.2 brought up the same error code. I drained it and must have been 10 litres came out - I don't remember having that much left in there in the past. There's no blockages in the waste plumbing. Does it sound like I need to replace the drain pump? Is that a common fault? Reckon we've had the machine well over 5 years now. Pump doesn't seem to be expensive but is there anything else I should check first? Should the spinny thing spin freely? Mine needs a bit of pressure and feels lumpy to push round. Would appreciate any wisdom! Quick update... last night with the machine still full of clothes and water after a rinse and spin failed to fix my E18 problem, I turned it to 'drain' and could hear faintly that the pump was trying to do something, so gave it a whack and it started working. So it seems that the pump is getting stuck sometimes and not other times hence the sporadic issue. Is it new-pump time or should I run it with a limescale remover... or something else I can try?
Root Admin Whitegoodshelp Posted July 31, 2025 Root Admin Posted July 31, 2025 Hi. If the pump wasn't running until you gave it a whack it would seem like it needs replacing. The impeller normally has some resistance but not too much. It's not meant to be totally free, it passes through a magnet. If something is wrapped around the impeller it can cause it to run slow and inefficient but you wouldn't expect a knock to free it off. People usually attach too much importance to small bits of stuff inside the filter. A washing machine can only detect and produce an error code if the filter or pump is blocked enough to properly restrict or stop the amount of water being pumped away. So it was more likely coincidence when you cleaned odd bits. More likely to have just been stopping the machine and trying later, which is in line with an intermittent fault on the pump. There are other possible explanations like moving blockage somewhere before or after the pump or electrical fault. But if it was struggling to run and a knock started it up its reasonable to replace pump. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Tozza Posted July 31, 2025 Author Posted July 31, 2025 1 minute ago, Whitegoodshelp (Andy) said: Hi. If the pump wasn't running until you gave it a whack it would seem like it needs replacing. The impeller normally has some resistance but not too much. It's not meant to be totally free, it passes through a magnet. If something is wrapped around the impeller it can cause it to run slow and inefficient but you wouldn't expect a knock to free it off. People usually attach too much importance to small bits of stuff inside the filter. A washing machine can only detect and produce an error code if the filter or pump is blocked enough to properly restrict or stop the amount of water being pumped away. So it was more likely coincidence when you cleaned odd bits. More likely to have just been stopping the machine and trying later, which is in line with an intermittent fault on the pump. There are other possible explanations like moving blockage somewhere before or after the pump or electrical fault. But if it was struggling to run and a knock started it up its reasonable to replace pump. Thanks Andy, I'll do that.
