Hi all,
I am having issues with my Miele wt945. There is no water going into the drum. I can hear and see water going into the detergent dispenser drawer and can also hear the water being constantly being drained/pumped out. I have cleaned out the filters (fluff filters, water filters)and even fitted a new triple inlet valve, also checked the water in and drain hose -which are both clean and good. If I put on a rinse or wash cycle i get the flashing red light for the "Water inlet/drain indicator".. but can hear (see if I open the drawer) the water going into the drawer but instantly being pumped out the drain hose - seems like it is bypassing the drum. On any cycle rinse or wash then drain pump is constantly running/pumping. The only way to get it to stop is to switch off the machine.
I have tried tipping the machine back, in case there is a anti-flood switch.. but no water has come out and also the bottom of the machine is dry
Thanks in advance
Edited by ewicc
Hi. This fault is coverred on my Whitegoodshelp common washing machine faults guide - Washer filling and draining at same time
